Is there any information about the documentVariables refering dimension settings for the RDocument. I know that there is a lot of variables that are stored on RDocument and could be queried by doc.queryDocumentVariables() . I have tested some modifications :
var doc = new RDocument(new RMemoryStorage(), new RSpatialIndexNavel());
var di = new RDocumentInterface(doc);
startTransaction(di);
doc.setKnownVariable(RS.DIMTXT,0.015); // text size
doc.setKnownVariable(RS.DIMASZ,0.02); // arrow size
doc.setKnownVariable(RS.DIMGAP,0.0125); // Offset from dimension line
doc.setKnownVariable(RS.DIMEXE,0.0125); // Extension line size after Dimline
doc.setKnownVariable(RS.DIMEXO,0.0); // Offset from origin
doc.setKnownVariable(RS.DIMBLK1 , "ClosedFilled");// 1st Arrow head
doc.setKnownVariable(RS.DIMBLK2 , "ClosedFilled");// 2nd Arrow head
doc.setDimensionFont("DejaVu Sans");
endTransaction();
But I can't guess the meaning of the behaviour of the following variables on https://qcad.org/doc/qcad/3.0/developer ... 8980966ebc . I would like to know the meaning of the variables that starts with DIM that I guess that refers to dimension settings.
Thanks
[solved] RDocument variables refering dimension configuration
Attach drawing files, scripts and screenshots.
Re: RDocument variables refering dimension configuration
An option is to Google them, maybe include 'DXF' in your search.
I am quite sure you will find some hits on the https://knowledge.autodesk.com site.
The DXF standard was developed by ACAD.
Ok, I get some info with the DXF standard at https://images.autodesk.com/adsk/files/ ... ce_enu.pdf , and get detailed info about that variables.
Thanks
Thanks
