I'm trying to edit a DXF.  This is using the latest version 3.25.1 on windows 7
I'd like to remove part of a line, The picture shows what I'm talking about. I'd like to remove the cut out and have it result in a straight line (forgive my mspaint skills).
I'm trying to get away from using rdworks as it won't export dxf's, so figured I'd give Qcad a go.
							How to remove points on a line?
				joebywan
- Capture.PNG (6.91 KiB) Viewed 2691 times
Re: How to remove points on a line?
Mouse: Rectangular Area selection from right to left (=cross selection),
Keyboard: hit delete key,
Work smart, not hard:  QCad Pro
What we see is probably a polyline ...
In that case 'Delete Node' OD (in the Draw .. poly menu)
Pls read the 'Forum rules' at the top of the page.
