Hi from Germany
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
Peter_108
Hi from Germany
Post by Peter_108 » Mon Feb 24, 2025 2:02 pm
Hi all
I am from Germany working for a city council. I am thinking about using QCAD for private purposes. I still need to figure out if my computer is good enough for QCAD. Therefore my first question to the forum would be the following:
What are the minimum requirements for a PC so that QCAD - 2D CAD can be installed/used? Which processor (e.g. the i5 series from Intel), which RAM (e.g. 16 GB), which storage (e.g. 512 GB) and which graphics card is sufficient for this? Do I even need a separate graphics card?
I would be grateful if anybody could tell me where in the forum I can get an answer to this question.
Many thanks in advance and kind regards,
Peter
J-J
Moderator
Re: Hi from Germany
Post by J-J » Mon Mar 03, 2025 1:01 pm
Hello Peter,
For info, I have been running QCAD Pro for a long time under Win7-64, I7-3.4 GHz, RAM 16Go
Biggest issue could be with very large files (several Meg)...
You can try the program with the free variant and see for yourself.
JJ Win7 pro-64
Re: Hi from Germany
Post by CVH » Mon Mar 03, 2025 2:10 pm
Also refer to the specific question about minimum requirements.
Return to “Introduce Yourself”
