I downloaded the Mac trial version (non-Intel) and it shuts down a lot without warning. I also cannot change the units between mm and inches.
I tried down loading different versions for various Mac OS and no luck. Is the Pro version this unstable also? Thanks in advance for any helpful suggestions.
[solved]Trial Version on Mac
Re: Trial Version on Mac
No.
Please try first to reset the QCAD configuration (ini).
https://qcad.org/en/tutorial-resetting- ... figuration
