[Solved]Step by step guide to nesting! Brilliant
Do you have a question you want to ask an existing QCAD user about QCAD and what you can do with it? Do you want to know if a particular feature exists? This is the place to ask.
chrispedersen
Post by chrispedersen » Fri May 21, 2021 11:49 pm
I've read the tutorial on nesting; it explained the principles well.
I'm accustomed to nesting with deepnest or svgnest, but I"d like to investigate QCad CAM.
However, even with my sheets defined and my parts to nest define I haven't found a way to nest.
Is there a beginner level guide for this?
Last edited by chrispedersen on Mon May 24, 2021 3:28 pm, edited 3 times in total.
Re: Step by step guide to nesting
Post by Husky » Sat May 22, 2021 12:45 am
Try this ...
https://qcad.org/en/tutorial-nesting
chrispedersen
Re: [Solved]! Step by step guide to nesting
Post by chrispedersen » Mon May 24, 2021 1:24 pm
Thank you so much!
1. Can nesting be accomplished in the webserver version via commandline or script?
The nesting is brilliant, but I'd hope to not use the mouse and command line at all.
Something like "nest sheet1.dwg, 8, part1.dwg, 3, part2.dwg, 4 part3.dwg,4" >> Sheet1.dwg, sheet2.dwg, sheet3.dwg
2. I created a sheet 72x120. I created a part 36x59 I was surpised that 10 minutes of running only placed 3 on a sheet. But the more important question is: suppose I have 8 parts, and two sheets. I made the nesting quantity for the parts equal to 8, and for the sheet equal to 2. But I don't seem to be able to make multiple sheets. [Edit:} Nevermind. Id10T error.
Re: Step by step guide to nesting- follow-on questions.
Post by andrew » Mon May 24, 2021 3:09 pm
chrispedersen: please post new, unrelated questions to a new topic, thanks.
Return to “Pre-sales Questions”
