How to remove points on a line?
joebywan
Post by joebywan » Sat Sep 05, 2020 1:51 am
I'm trying to edit a DXF. This is using the latest version 3.25.1 on windows 7
I'd like to remove part of a line, The picture shows what I'm talking about. I'd like to remove the cut out and have it result in a straight line (forgive my mspaint skills).
I'm trying to get away from using rdworks as it won't export dxf's, so figured I'd give Qcad a go.
Re: How to remove points on a line?
Post by Husky » Sat Sep 05, 2020 3:43 am
Mouse: Rectangular Area selection from right to left (=cross selection),
Keyboard: hit delete key,
Post by CVH » Sat Sep 05, 2020 4:33 am
What we see is probably a polyline ...
In that case 'Delete Node' OD (in the Draw .. poly menu)
Pls read the 'Forum rules' at the top of the page.
