setCurrentLineweight & setCurrentLineweight functions not found
This forum is for 'Work-in-Progress' QCAD user developed script Add Ons and Plug-ins.
Please use this forum to request/submit your script Add-Ons & Plug-in idea's.
dfriasb
Senior Member
Post by dfriasb » Thu Mar 26, 2020 8:59 pm
Dear all,
I can find and use setCurrentColor in Script Shell, but not setCurrentLineweight or setCurrentLineweight. Is there a way to "load" and use them? I'ld like to use them both in Script Shell and in script files.
Thanks. Best regards,
David
David Frías Barranco | architect
[email protected] | davidfriasarquitecto.es
Re: setCurrentLineweight & setCurrentLineweight functions not found
Post by CVH » Fri Mar 27, 2020 4:24 am
Looked it up:
https://www.qcad.org/doc/qcad/3.0/devel ... ml#index_s
•setCurrentColor() : RDocument , RDocumentInterface , RStorage
•setCurrentLinetype() : RDocument , RDocumentInterface , RStorage
•setCurrentLineweight() : RDocument , RDocumentInterface , RStorage
So all 3 are equally implementent.
Would be handy to know:
The use of setCurrentColor() that works for you.
The others that fail.
A Typo maybe?
dfriasb
Senior Member
Post by dfriasb » Sat Mar 28, 2020 8:48 am
It's working in custom scripts. Thanks CVH!
Return to “QCAD 'Script Add-On & Plug-in challenge' - Work in Progress”
