DXF Troubleshooting
Posted: Thu Jul 06, 2017 11:13 pm
We are adding SPLINE support for our DXF output-format for Gendl, our open-source KBE system (http://gendl.org).
I hope this is an appropriate place for this post. I'm trying to find some pointers for debugging what appears to be a subtle issue with a DXF file we are trying to output, containing a spline.
The attached DXF opens fine in QCad, but fails in Autodesk A360 viewer.
So apparently QCad is more forgiving than Autodesk A360 viewer. Is there a way in QCad to examine the DXF file for any "warnings" or malformed input, or can anyone see something obviously incorrect with this file? Removing the SPLINE entities results in it working in Autodesk 360 viewer -- so apparently there is something wrong in the SPLINE entities.
I've attached the text-format DXF file as well as a screen capture of how it looks when opened with QCad.
Best Regards,
Dave Cooper
genworks.com, gendl.org
Best Regards,
Dave Cooper
