New User with a question
Post to this forum to introduce yourself to this forum if you are new here. You might want to include some information about the work you are doing or planning to do with QCAD.
Buzz239
Post by Buzz239 » Sun Dec 09, 2012 10:15 pm
Hello to everyone in the group,
A few weeks ago I purchased QCAD and I am very satisfied with the program. I use KCAM4 as my CAM program. I use the combination QCAD/KCAM4 for CNC engraving. I designed a plaque using circles with lines as spokes. I used the letter function to depict several formulas and designations. It is saved as a dxf file. KCAM4 has the ability to convert the dxf file to Gcode. The problem is that when the dxf file is converted to Gcode in KCAM4 I lose all the lettering. The circles and spokes appear but no letters. Is there something that I am not doing to the text that is causing this to occur? Any ideas on what the problem is?
TNX Buzz239
Re: New User with a question
Post by Husky » Mon Dec 10, 2012 3:02 am
Hi Buzz239,
just a guess but have you explode the lettering before you saved it with QCAD? Maybe just give it a shot and try then to convert this new dxf file to Gcode ...
Return to “Introduce Yourself”
