Dotted Line at Metre drawing unit
Posted: Sun Oct 26, 2025 9:35 am
I'm having problems when printing a small (relative to the drawing unit) dotted line as part of a title block. when screen-based linetypes is turned off it represents as a series of overlapping lines.
The linetype is 'ISO dot' - but it seems to occur with the the other dotted line linetypes, and I've tried adjusting the linetype scale upwards at various intervals beyond 1000 and downwards below 0.0001. Adjusting the lintetypse scale upwards reduces the number of overlapping lines, ultimately down to 1 but this does not represent the shape any more; adjusting it downwards removed the overlapping lines from 0.3 and below but the line appears continuous rather than dotted, until you get down to 0.000001 where the overlapping lines return.
This issue does not appear where the drawing unit is in millimetres, but I need the drawing unit in Metres.
It seems to be an issue with how Dots are rendered as it only seems to happen with line types that have a 'dot' element, such as iso dot, iso double dash dot, border, divide, dot etc.
I've attached an example file below
Any ideas as to how to solve this?
I'm running Windows 11 and QCAD ver 3.32.4
James
James
