HI,
Would you please tell me how to get read/write a block attribute ?
Thank you
Michał
ECMAScript block attributes access
Attach drawing files, scripts and screenshots.
Re: ECMAScript block attributes access
With an RDocument reference in doc, all entity ID's of the type EntityAttribute:
Or all entity ID's of the type EntityBlockRefAttr:
In some way you need to filter on the intended attribute with querying the attributes themselves by id.
The RAttributeEntity has several methods including reading/writing the tag content, the plain text and so on.
See reference
The parent Block Reference id can be retrieved by a method of the REntity class: attrib.getParentId()
See reference
Then:
On any change you have to cast the entity back to the document (With an RDocumentInterface reference in di):
If this doesn't answer your question then please provide some code where a known RAttributeEntity must be read or written.
Or a drawing with block attributes and what to select to alter.
var attribIds = doc.queryAllEntities(false, false, RS.EntityAttribute);
var attribIds = doc.queryAllEntities(false, false, RS.EntityBlockRefAttr);
var attrib = doc.queryEntity(id);
See reference
See reference
Then:
var op = new RAddObjectOperation(attrib);
di.applyOperation(op);
Thank you for your thorough answer. I'll try it out.
Michał
Michał
